landyacht318
Feb 13, 2016Explorer
Try calling Errin at powermax converters about warranty. Randy is just the middleman with the 'click order' on his website and not early as good a grasp on battery charging as he would like his customers to believe.
The Meanwell rsp-750-15 claims to have a maximum input of 8.2 amps @ 115Vac which would be a 943 watt load at a claimed 92% efficiency.
http://www.meanwell.com/mw_search/rsp-750/RSP-750-SPEC.PDF
Use as fat of wire as possible which will fit the terminals. Set to 14.8v unloaded, then hook to battery.
The casing will get hot at maximum output. Consider adding more ventilation and or sticking some heatsinks to the casing sides adjacent to the transistors
