JamesJudasPries's avatar
Mar 28, 2015
Progressive Dynamics - max current before overload
Hello all,
I am trying to figure out what the max power output of a PD 9145 converter is before its brain decides there is an overload condition- and also, what it does to solve that.
through my experimentation, I have attached short chunks of #4 wire with lugs directly to my 2 golf cart batteries, brand new, discharged to about 50%. With my DC clamp meter, I measured 47 amps @ 12.6 volts when i plugged in the converter to an ac outlet. The charge wizard pendant had also been installed on the unit.
My question is, just how low will the converter output voltage get in order to control current to the max 45 amp output. The paperwork says the converter's full load current is rated at 45 amps and about 12.6 volts. I understand the fact that at the batteries state of charge rises, so will the converter voltage until max 14.4 is reached at full current, and then the battery demand will taper.
So what if someone has maybe 4 or six golf carts which will demand significantly more than 45 amps if heavily discharged? surely the converter would have to drop to maybe even 12.0 volts or lower to control the charge current from climbing past max output. Would the PD9145 simply consider this overload condition if the batteries demanded too much current at a voltage below the 12.6 min spec? And does the converter shut off completely at this point?
