westend
Sep 11, 2014Explorer
09FLSTC wrote:Probably up in heat as the circuits in the converter are still powering components, even while in float. "Warm to touch" is not typically a problem. If you were to enlist a bunch of ideas about cooling the converter, it may still dissipate the same amount of heat, hence same power consumption.tenbear wrote:
When I first switched to the PD9260 I noticed the power bill went up by several $$. I couldn't think of any other cause so I switched to a Battery Minder for use during storage. My bill dropped down.
That indicated to me that the PD was drawing current while not doing very much. I never did feel it to see how warm it got, nor did I measure the current drain.
Huh? So where do you think that energy went?
Isn't there any information from PD about the current used while in various use?
Edit: Answer #6 from the PD Converter Faq would seem to contradict the OP's experience---
"6. Does my Converter/Charger completely shut-off when the battery reaches full charge?
When the battery reaches full charge, the charging current of the converter drops down to between 20 and 25 milliamps. Batteries will self-discharge themselves at this low rate even when no other 12-volt current loads are present. The converter senses this current loss and automatically replaces this lost current to maintain full battery charge."
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
