bigfootford
Sep 15, 2014Nomad III
kincade wrote:
Ok, after running the trailer on my Kill A Watt for 2 days, here are the draws I see:
Wattage fluctuates between 16.5 and 17.9W
.29 A
.47 PF
34.7 V/A
at. $.11/KW, it's costing me about 16.38/yr to maintain the batteries. Not a huge expense, but it might be worth using the battery minder during the winter to cut down on electrical usage.
When I put a larger appliance on, the PF goes up to .99 (fridge, etc).
Thanks for all the advice in this thread, I sincerely appreciate it!
So our Progressive Dynamics are quite close at idle/float.
Watts vary between 15-20
Amps varried a bit... .19 - .26
If your battery minder does not go into boost mode every day or so I would not use it for storage.
Jim
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
