full_mosey
Feb 20, 2018Explorer
NEOK wrote:
1.Will the charger in that converter work with AGM battery?
2.Could the charger keep both batteries charged?
Thanks
If the AGM is inside and usually near 25C/77F, then yes.
1. Many AGMs require or recommend a temperature compensating charger. My AGM dropped from 10C to 0C today. The solar controller has temp-comp and it set the charge volts to 15V today in OKC. It would have set higher, but I cap the Volts at 15 to protect onboard electronics.
The PD does not do that and 14.4V may be too low in Winter. Do you know the specs of your AGM?
2. Yes, if the the load and charge(POS) lines are on one battery and the load ground(NEG) are on the other one. This keeps the round trip line length 'balanced'.
Otherwise the batteries will not stay balanced. One battery will be wear out faster than the other. Batteries in parallel work best when they are in the same condition/health.
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
