DrewE
Aug 22, 2016Explorer III
JamesJudasPriest wrote:
YES, Ok I have been wondering this as well.
It is clearly documented what the lights mean when plugged into 120. But what I want to know is what the lights mean when it is just monitoring battery voltage and there is no AC source to the converter. I have noticed the LED blinks, but does anyone know what voltages the blinks mean??
The light blinks simply indicate what voltage setpoint the converter is using (if connected to 120V power) or would be using (if not connected to 120V power). I'm not sure they correspond directly to battery voltage levels or state of charge. If you want to know the battery voltage, it's much more instructive and useful to just put in a voltmeter and read it directly.
Note that the voltage setpoint may not be the output voltage of the converter if it's rather heavily loaded. In particular, with a discharged battery, it will be limited by current (or power, which amounts to almost the same thing) and put out less than the 14.4 volts a solid light indicates until the battery gets more charge. In other words, the converter acts more or less like a current limited voltage regulated supply.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
