time2roll
Apr 23, 2018Nomad
brulaz wrote:My MC4 wire is rated 600 volts. And yes you can get a controller rated 600 volts input.
Watt limitation on solar wiring? I've only heard of the 30A limit on 10ga and 20A on 12ga. Always presumed that was good up to 100V, the usual mppt limit.
My home system uses the same wire but operates at 450+ volts to the grid tie inverter. Panels rated 3kW.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
