- ktmrfsExplorer IIIMHO buy the biggest PD unit you can run with your generator. 65/75A is about the limit for most 2000VA generators.
and if the trailer came with the (in)famous WFCO generator, yes going to a PD is a good idea. If so, put in the PD drop in replacement, good to go, I think they make a 55A and 65A drop in replacement.
Now if your generator is 3000VA or bigger, then you could get a 100A PD mount it in the pass through, and be good to go. - landyacht318ExplorerWith No solar and generator I would not fear running the PD-9260-14.8, that has the 14.8v absorptoin voltage instead of the regular PD 14.4v.
Getting to 100% is important for any lead acid battery but especially so AGM's. I would not recommend going more than 7 deep cycles without getting to that desirable endgoal, and after 7 cycles it might require significantly more time at absorption voltage for amps to taper to 0.5% of capacity(20hr rate)
A hundred watt solar panel has the time to hold the batteries at absorption voltage, silently, after the generator has gotten the batts to ~90%, and can greatly extend battery lifespan. - AlmotExplorer IIIIn desert? Put some solar on the roof. The issue with charging battery correctly is more about getting it to upper 90% than keeping correct voltages, and generators are not good at getting it to 99.9. Takes a lot of time.
Converter should match Bulk/Absorption voltage of your AGM. And fit into space where the old converter is living now. There isn't much else to it. - Rail_DawgExplorerYes the Trojan T-105 does have an AGM version which is what we’re buying.
http://www.trojanbattery.com/product/t105-agm
Thanks! - 2oldmanExplorer II
pauldub wrote:
Maybe the T105 comes in an AGM version. Just maybe.
The T-105 isn't an AGM, it's flooded.
Perhaps OP should put that in the Subject since so many people only read that. - BFL13Explorer IICharging instructions for the AGM T105 here. Note the 217AH vs 225 for the Flooded T-105 if that matters to anybody.
http://www.trojanbattery.com/pdf/T105-AGM_Reliant_DS_Final.pdf
PD has a newer version of their standard converter that does 14.8 instead of 14.4. However, that would only be needed to do the "finish charge". Your 14.4 would do for normal recharging, but do have the Charge Wizard to be sure you can get it to do 14.4 instead of just 13.6.
If you fast charge at say a 25% rate, that would be 54.25a so a typical 55 amp converter should be just right. - pauldubExplorerThe T-105 isn't an AGM, it's flooded. The PD converter that I have won't deliver the charge voltage that Trojan specifies for the T-105. If you're really going to dry camp a lot and in sunny places, you might want to consider solar charging. It takes a lot of generator hours to fully charge batteries.
- 2oldmanExplorer IIWhat brand of converter do you have? AGMs do have a slightly different charging algorithm.. is that what you're asking about?
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
