Ed_Gee
Dec 02, 2018Explorer II
You overlook the substantially lower internal resistance of the AGM battery. The charging process is essentially the conversion of electrons ( current ) back into chemical storage. In a wet cell much of the current is wasted as heat due to that higher resistance. In an AGM less heat and faster conversion process.
I also want to point out that the greater efficiency applies to all AGMs, not just LifeLines.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
