BFL13
Dec 03, 2018Explorer II
DAS26miles wrote:
Checking with PD intelli-power and says it works with AGM's. Looking at Duracell Utra Platinum Group 27 AGM's. $220 each less 10% ordering online and picking up. Not too bad. Just the 92ah I don't care for. I was hoping for 100ah but if it recharges 5 times faster, it shouldn't make a difference. I was using my generator for and hour in the morning and 2 hours in the evening and still down 10 accumulating amps per day. Solar only kept it from dropping any further in daytime. But by third day I was down 30 amps on the third evening after charging. I'm hoping that the AGM's will get it charged back closer to full. I know part of the issue is the PD Intelli converter chgarger claiming to get the batteries up to 90% within 2-3 hours and another 15 hours to fully charge.
Say you head out with a full pair of 27s at 180AH. You don't need to recharge until down to 50%.
If you need to run the gen for an hour next morning, that means you used 90AH. So you do a 50-80. 30% of 180 is 54 AH. Can you get by till morning? Doesn't look too good if you use 90.
If you do the 80-90 another 10%, that's 18AH more for almost another hour of gen time, so you replaced 54+18= 72AH. Not enough to be above 50% next morning.
You need more battery! Get two 6s instead of two 27s. Bank is now 225AH, leave home with that and next day down 90 to 60%, and do a 60-80
So up 50AH and at 80% or 180, and do another day of 90, now down to 90/225= 40% Now you need some gen time for the morning of the third day. A 40-80 is 40% or 90AH so back in business.
Do 40-80s. How often? A couple more days, no big deal going just below 50%. How many times a year? Or do a 40-90 and then a 50-90.
From the OP's description, besides other issues, it looks like recharging by gen when already above 80% so a low amp, long time recharge to get not many AH restored. That is why they invented the 50-80, so as not to waste gen time. Recharge down in SOC where the batts can accept all the charger's amps.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
