time2roll
Oct 22, 2013Nomad
Every 21 hours it does boost mode for 15 minutes. Did you get lucky?
Otherwise first suspect is the battery. Disconnect the battery negative and let it rest. 4645 can stay on. See if the battery holds 12.6+ volts after several days.
How is the water level?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
