westend
Oct 22, 2013Explorer
Shadow Catcher wrote:There should be a ground from the AC load center to frame. Neutral should never be tied to ground, frame or other. Also, nothing wrong with having all DC grounds tied to one ground to frame or another for battery ground to frame.
The common is one side of the AC and is not the ground, It means you have 120V running through the frame. Everything in our aluminum frame trailer has a separate ground and now nothing is 'grounded' to the frame.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
