xzyHollyxyz
Oct 20, 2013Explorer
tenbear wrote:
If you can measure the voltage at the converter, 14.4v is boost, 13.6v is normal and 13.2v is storage. If you measure it at the battery the voltage will be lower due to the losses in the wiring.
I just went out there and measured the voltage at the converter. It was 13.60.
So, does it take over 24 hours to enter "storage" mode?
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
