wa8yxm
Oct 20, 2013Explorer III
The light, is nothing more than a volt-meter.
IF you have a system set up like mine
Batteries---(Some loads and disconnect system------Main fuse block-----Converter
You may well never go into float as the loads suck it down just enough to keep it in boost. NOTE the voltage at the battery will be lower than at teh converter which in my case is over 50 feet of wire away (Each way)
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
