SoundGuy
Nov 14, 2015Explorer
CA Traveler wrote:
Unfortunately the unit does not have a battery and if pedestal power turns off/on then the unit resets and there is no fault displayed.
Bobbo wrote:
This is true, just like you had unplugged and driven to the next campground. The unit can't tell the difference between complete power loss at the pedestal and you unplugging the RV.
I guess I'm just not seeing the problem ... if I'm in the trailer and power drops out the EMS display will go blank, if I'm away from the trailer at the time and return later after power has been restored I'd still instantly know that had happened because the clock display on the microwave oven would be blank. If this is such a concern for you have you contacted Progressive and suggested a "voltage dropout" feature be included in the remote display functionality? :@
