SoundGuy
Nov 15, 2015Explorer
Bobbo wrote:
Personally, I think that is a solution in search of a problem. Like others have mentioned, my MW tells me if the power was off. If the EMS shows no previous error codes, I know the pedestal power was off. That gives me all the information that is being discussed here.
Well not necessarily ... if your camper is powered with everything running fine, then you leave and power goes off during your absence but is restored before your return, you wouldn't know at all from the EMS that power had been off unless that power disruption had been accompanied by some sort of fault such as the open ground situation I described earlier. I agree it's not much of an issue when a quick glance at the microwave oven will tell you if there has been been a power disruption during your absence ... perhaps that's Progressive thinking as well, though it would have been a handy feature to have included in these EMS units.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
