Atlee
Jan 15, 2014Explorer II
No, I got it strictly to use should I find the 30 amp broken.
However, as the poster after you suggested, it might be good to use it all the time since the 50 amp outlet sees much less wear than the 30 outlet.
GMCPU53 wrote:
Hope this question doesn't sound too stupid, but does the use of the dog
bone from 50 to 30 amp, give fewer problems, or more consistent power ?
I have a progressive unit also, and had one time it kept kicking out at a Campground due to faulty ground issue. Have a dogbone on hand , and will use it if it improves things, thanks Joe
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
