aruba5er
Jul 14, 2014Explorer
Did it burn where you connected the cord? If so than it was a loose wire that caused the problem. Tinning( solder) is no longer recommened as the solder itself is not that good a conductor (lead). Plus you can overheat the wire and blue it. best yet is to just put the wire into the hole and tighten it. DO NOT twist the strands, just lay them in. I can't believe they gave you static rather then helping you get the problem solved as many GOOD things have been said about Progressive. I think i'll go out and check to see if mine still is tight. Wires will lossen with age.
