tomdrobin
Jul 16, 2014Explorer
ktmrfs wrote:
BTW I have the same unit, used it for almost 4 years, and probably approaching 300 days. So far it has performed wonderfully, although yes it does get warm (not hot). In fact this weekend it alerted me to a intermittent open ground at the pedistel.
Mine performed flawlessly for 6 years. The only problem it found though was when I used my portable generator. It seems the generator has a floating ground, and the unit doesn't like that. If the processor is generating some heat, that is to be expected. But, heat from high resistance in the main line IMO, should trigger a shutdown. It protects you from a defect in the source, it should also protect you from it's own internal failures.
