vermilye
Jul 16, 2014Explorer II
ktmrfs wrote:
in my company solder dressing leads under a screw connection was a no-no. This was on equipment that had to meet MIL288800B environmental conditions. solder cold flows, it is soft, even the lead free. over time the connection begins to loose compression, end result is heat.
2X.
Prior to my retiring, part of my job was maintaining a theatre lighting system. That included many miles of 12/3 S extension cords. When the original cords were supplied with the theatre, NY state required tinning of the stranded wires at the connectors. We continually had problems with the connector screws loosening, causing intermittent connections, or overheating of the connector. When we built our own cables, we didn't tin the connections, and had far fewer problems with loose screws.
