I have not seen a size of the tank on it, but can look next time it stops raining! The MH brochure says it has a 76 lb tank. If they use different temperatures as the "standard" for tank size, I suppose that would explain minor differences in "sizes"
I somehow thought I now had a huge amount of propane compared with before at two 30s. Maybe not? Same as?
Actually, I only think he said it was 26 litres. After he filled the tank he looked at at the pump numbers, then went to a little terminal beside that and tapped in a bunch of numbers, and then that spit out a slip of paper, which I took in and the cashier did something or other, and it came out as $26 on my Visa. Propane is about a dollar a pound but it is also approx. a pound per litre so I don't know. I was not paying enough attention obviously. Next time for sure!
