ChiefUSN's avatar
ChiefUSN
Propane BBQ issue
Recently purchased a new BBQ and it has a hose that connects to the LP propane outlet on the trailer (no regulator on the BBQ side). The outlet has a quick-connect type fitting with a shut-off valve (like this). This is my first attempt at using this fitting.
When I connect the BBQ to the trailer, I get no (or very, very little) gas flow. Not enough to light the burner. To rule out a defective BBQ, I borrowed a friends adapter hose that connects the BBQ to a 1-pound disposable. With this configuration everything works just fine.
Thinking that the issue has to do with the trailer side, I traced out the gas lines and found that the same line feeds all the LP appliances. There's simply a "T" where the quick-connect hose is attached to the supply line. All the other appliances work fine.
Is it possible the quick-connect fitting is bad or is there other things I should try?
  • Nope, no regulator on the grill. The grill is a
    Camco 57305 Olympian 5500 Stainless Steel Portable Grill.
  • Your new grill probably has a regulator that needs to be removed for it to work.
    Tell us what grill you got and maybe someone will have specifics.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
