miatared's avatar
miatared
Propane delivery noise
I have a new Cougar, furnace comes on, fan runs, normal expected noise.
After the set time, propane delivery starts, furnace fires up and heat is good.
But when the propane delivery starts, it sounds like a jet engine, very, very loud.
I've looked at the LPG line, to see if it rattled with something... Could not find anything.
Anyone has any idea?
Thanks.
  • ok...hadn't heard that. if so it may mean less choices for us.
  • miatared wrote:
    Good idea. It's brand new, so I guess it needs adjustment. Will look into it.
    It's a Dometic / Atwood.
    Thank you
    which one...dometic or atwood? but if it's new that should be a warranty item. good kuck.
  • Good idea. It's brand new, so I guess it needs adjustment. Will look into it.
    Thank you
  • sounds more like the burner. can the flame be adjusted?
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
