Old-Biscuit wrote:
vtchris wrote:
Yes, piezo ignition. There is no control board, this is an old fashion type gas/electric fridge. And I don't know how to take the burner apart and clean it. Can someone explain?
Service Manual that covers your model
Problem with flame going out could be 'bypass' setting/propane pressure and or 'flue cap' out of position. More then likely issue with 'bypass'
Since he appears to have a bypass tstat, LOW LP pressure would also cause this. The refer runs on normal flame, but because his LP pressure is LOW, when it goes to Bypass, the lack of correct pressure causes the bypass flame to not be large/hot enough to keep the Thermocoupler engaged. Doug
Sorry, did not see your LP pressure part of the response.
