Almot
Jul 28, 2014Explorer III
Propane fuel filter for catalytic heater?
Getting ready for catalytic space heater. As often happens with small US businesses, ETA is unknown. Leaves me ample time to get all the fittings. Perhaps too much time, as I suddenly remembered about "inline propane filters".
I know about oils leaching from rubber LP hose. But can anybody tell me if I should be worried when there is NO hose? I will be using upright 66 lb propane cylinders on a seasonal site. There is usual 3 ft hose from the tank to black iron pipes of trailer, and then 3/8" copper tubing. Can rust or mechanical impurities in the cylinder and pipes cause clogging of some orifices inside the heater or, worse yet, clogging $$$ catalytic element?
Neither Platinum Cat heater, nor Camco aka Olympian Wave mention any filters.
Mr. Buddy non-catalytic heater has optional $10 inline LP filter, it needs to be replaced annually or sooner, because it clogs. Weird hose fittings.
And there are few other inline filters, like this 600 PSI filter, with normal flare and NPT threads. Probably needs to be replaced once in a while too. Expensive.
Big question is - do do I need it?
