path1's avatar
path1
Propane gauges on tanks question
Trailer is 2013 and the propane "sight level gauge indicator" doesn't work right. Supposed to be "green" when enough propane is in tank then turn "red" when tank is empty. Then the turn knob and use propane from other tank.
Problem on 3 different gauges has been... The green shows until both tanks are empty. I replaced original propane regulator with same make and model as OEM. Still didn't work right. Then last winter replaced again with one that a large propane dist said they get very few returns on.
So that's 3 propane regulators with "sight gauge" not working right. The odds of 3 of them being bad seem highly unlikely to me.
Is there anything I should check or do?
What I'm I missing?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
