dougrainer wrote:
mkirsch wrote:
When you disconnect the tank to refill it, you introduce air into the system.
How is air introduced to the system???????? Doug
PS, You do NOT!
Um, yes, you do.
When you disconnect the line from the valve on the tank, there is that little open hole there. Propane puffs out, replaced by a slug of air. When you connect the line back to the filled tank, you trap that slug of air in the line.
Happens to me every time I change tanks. There's always a bit of air to purge which causes a brief lapse in flame quality.
It's not rocket science.
