waynefi's avatar
waynefi
Propane leak
My trailer developed a propane leak recently. It was enough to empty a tank in two days. The first time a tank emptied quickly, I thought that the exchange hadn't given me a full one. The second time I started checking, and found a leak in the fitting that connects to the tank. It was enough that I could feel the breeze.
Fortunately, the leak was outside the trailer.
  • Manufacturers recommend that the LPG system get a thorough check annually. Among other things the system pressure is tested and adjusted and the system is tested for leaks.
    Glad you discovered it before it became a big problem involving flames.
    kayakcrazy wrote:
    I always check mine using soapy water and a small paint brush....
    I check mine with a manometer.
  • I always check mine using soapy water and a small paint brush. I keep the mixture handy so I don't have to mix every time. If we have been doing a lot of travelling I will often check the connections mid way between fills.
Having RV issues? Connect with others who have been in your shoes.24,238 PostsLatest Activity: Apr 24, 2025
