2001400ex
Feb 22, 2015Explorer
Propane leak
I have a propane leak, found it when I got home from my last trip last year, been lazy on getting it fixed. I have dual tanks and the full one leaks, so it's after the tanks, somewhere in the line to ...
SAR Tracker wrote:2001400ex wrote:
....I read that this is a large pain to find the leak....
Not really.... turn the gas on, and start spraying EVERY CONNECTION with a soapy water solution. When you find the bubbles, you've found the leak.
I'm willing to be it's the regulator between the two tanks. They're notorious for failing.
