mbrooks43 wrote:
I have a '16 Montana 3710FL. It has two 30# / 7gal tanks but after about 3-4 days a tank is empty. The furnace runs on propane as well as the stove when used. The fridge ran on it for about 12hrs but electricity since then. Does that sound reasonable? Furnace is set at 65 during the day and 63 at night.
You haven't provided any information about your furnace but let's say a pound of propane provides you with an hour of furnace run time, in which case you'd obviously deplete a 30 lb tank in just 30 hrs of total run time on the furnace alone. Obviously any other gas use such as the stove, oven, fridge, water heater, etc, would reduce what's available for the furnace. Since you haven't told us how cold it was outside or how frequently the furnace was runnning it's impossible to say whether this gas usage is excessive or not.
