mbrooks43's avatar
mbrooks43
Propane leak?
I think I have a propane leak. I have a '16 Montana 3710FL. It has two 30# / 7gal tanks but after about 3-4 days a tank is empty. The furnace runs on propane as well as the stove when used. The fridge ran on it for about 12hrs but electricity since then. Does that sound reasonable? Furnace is set at 65 during the day and 63 at night.
  • Does your RV have a built-in leak-down gauge? My 1990 Winnebago Warrior does.
    You turn on the gas, adjust the site needle to match the current pressure, then turn off the gas. Check on the gauge some hours later - if the two needles no longer match (pressure has dropped), you have a leak.
    Steve
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
