fred42's avatar
fred42
Propane Leak
I have a 30 lb LP bottle on each side of my fifth wheel. On the last trip, I returned to the camper to hear what sounded like water spraying out somewhere. It was propane escaping from the device shown below. It was the bottle on the sunny side behind a black door. Perhaps it was full and got too hot producing an over pressure situation?
If you see the black dot at the 9 o'clock position next to the protruding cylinder, that is a hole and gas is coming out very fast.
I shut the tank off. I am home now and want to fix it. Does anyone know what the purpose of this device is and what gas from that hole indicates? The tank on the other side has the dual tank switchover regulator that you would expect to see. It is much cooler here at home but if I turn that tank on gas still escapes from that hole.
This is my first attempt at using imgur photo hosting instead of PhotoBucket, so I hope it works.
thanks very much,
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
