ktmrfs
Oct 11, 2016Explorer III
red31 wrote:
Dr Quick, why was the excess flow feature not resetting itself on its own as designed? With all appliances off, if the excess flow feature activates there is enough gas flow to fill the lines and balance the pressure of each side of the little ball and then the excess flow feature resets (spring pushes ball out of the way).
Yours may have malfunctioned or gunked up. Replace ACME pigtails.
I can hear the ball when I open a container and then hear it reset.
My experience is that they seldom reset unless you completely relieve the pressure. not just turning off the tank valve. once set, they tend to stay set.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
