BFL13
Oct 11, 2016Explorer II
djousma wrote:
I've always left both tanks open, unless storing for a prolonged time. I too have the auto switchover valve between them. I just occasionally check the indicator on it, and if red, the tank to which the lever is pointing is the empty one. I switch the lever to the other tank, and know that its time to get the other tank refilled.
Most advise to leave the lever pointing at the empty so it stays red until you actually take the empty out to refill it. Otherwise you might forget and see the green thinking all is well till you have two empties.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
