Horsedoc's avatar
Horsedoc
Explorer II
Feb 14, 2018
Propane odor
Getting everything ready for a early spring trip and tried the stove the other day. No propane. I was pretty sure I filled the tank after the last trip.
Filled it and now I am smelling gas. This coach has buttons to turn the valves on and off at the tank. I cannot get to the tank! It is mounted in front of the basement just under the cockpit area (I think)Isn't there some national rule about plumbing gas with iron pipe or is that just residental stick housing?
Trying to figure how to get under the coach to see exactly what is causing the leak and how I will be able to manuever tools under there.
Any help? (coach is a 2008 Damon Essence on a Freightliner chassis.
  • To fill the tank the attendant will open the over-pressure valve to release pressure as new gas is pumped in. Once the tank is full the over-pressure valve is closed. If the attendant didn't close the valve completely or it's bad you will smell propane.
    Also check all connections with soapy water solution to search for leaks.
    If there are rubber supply lines to and from the regulator, check them for cracks and leaks with the solution.
    Have a fire extinguisher close at hand just in case.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
