Ric_Flair's avatar
Ric_Flair
Propane quick disconnect fittings
Can't find them locally.
Looking to attach a line from the female quick disconnect on the outside of my trailer to a propane burner.
I guess what I need is the male on one end of the line and the fitting with orifice on the other.
Anyone have a link or a solution?
  • I just need to find out what the correct orifice is for a propane burner. I have the line with regulator on one end and orifice on the other that came with the burner, but can't take the orifice fitting off
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Ric Flair wrote:
    Here's another question. I'm assuming it's low pressure. Is that not right?
    Yes, it's low pressure.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Ric,
    Here's how I did my Weber Q, yours might be similar. Calore has the 1/8" male pipe thread fitting and hoses. I removed the regulator on my Q. Maybe this will be relevent to your situation:
    WEBER CONVERSION
    yes low pressure most likely the ones you are looking for are low pressure series 250 i beleive they are couple safe 250 but read the female fitting to make sure the info is on the pull back ring of the fitting or on the neck of the male fitting
  • try this
    http://gashosesandregulators.com/propanequickconnect.html#rvhoses
    http://www.propaneproducts.com/catalog/quick-connectors-39-1.html
  • Here's another question. I'm assuming it's low pressure. Is that not right?
  • Dang it, that's what I'm finding. I have 3 right now, all 1/4 male.....none of them fit the female.
    I just want to avoid pulling the tank out every time I want to use the burner and just plug into the quick connect.....which is what I assume it's for
  • Amazon carries the Camco ones and others, beware they are not all created equal. I mean that they do not always fit each other. Stick with one brand.
    Mr. Heater makes some nice ones too.. but they won't work with the Camco ones..
    frustrating!
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
