monrcar's avatar
monrcar
Propane Regulator leaking on Street Side
Hi,
My Cougar 5th Wheel (6 years old) has a stand alone 18psi (GR-618) red regulator on the street side propane bottle, which enters a pipe that crosses the front to the curb side. On the curb side is the standard switching regulator. I put the street side bottle on service and got a major leak from the vent hole on the GR-618 regulator. (Blowing propane). I read about the 2nd regulator on this "closed" topic:
(http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23537608)
I've also read on two other forums persons have had the same leak. (Google search: LP GR-618 LP regulator leak) But very limited additional information.
I'm concerned this may be a common problem with these 2nd regulators. I'm thinking of just capping the pipe from the street side bottle and physically swapping bottles when needed rather than risk an un-controlled propane leak.
Any input appreciated. And have others experienced this problem?
edit: Here is a picture of the leaking regulator. Leaks at the vent hole below the "S" in "PSI"..
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
