wa8yxm
Mar 27, 2014Explorer III
If you have ever taken a regulator apart (I have, though it was a water pressure regulator, however they work by the same theory) then you know how they can fail.
On the Water pressure regulator I have a spring pushes against a diaphrham, This spring tries to push the valve OPEN.. water pressure on the other side tries to CLOSE the valve, the valve is a common washer type valve on this regulator (May be a needle valve on the propane job, Do not know)
If something jams the seal, or if the seat is nicked, or if the diaphragm membrane is ruptured or any of several other things happen.. It fails.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
