jpratt2's avatar
jpratt2
Propane smell after filling
Hi all: We're presently on a trip though Idaho and Utah. I had the propane topped up at an RV park and now several hours later there's an odor of propane on the outside near the tank despite having driven 100 mi. No smell inside.
I've noticed this before after fill-ups. Is this common?
Also, I have to admit being rushed during the full-up and (like an idiot) did not shut off the tank main valve first. Could this be an issue?
We're avoiding using any propane appliances until I figure this out.
Thanks in advance.
  • Then my bet is the guy who filled the tank did not close the bleed valve completely
  • Maybe got filled too full, and slowly bleeding off as the temperature rises ?
    Like said above, make sure the bleeder valve is off tight.
    Remember, a tiny bit of that smell goes a long ways.
  • Permanent tank or refillable cylinder
    Could the filler not have shut the bleed valve completely
Having RV issues? Connect with others who have been in your shoes.24,303 PostsLatest Activity: Aug 21, 2025
