dougrainer
Dec 13, 2016Nomad
The purpose of the Auto change over Red/Green is to give a visual indication when the primary tank runs out of LP. You POINT the lever at the tank you want to use FIRST. Leave BOTH tank valves OPEN. When the FIRST tank runs out of LP, the system auto changes to the 2nd tank. Then that green goes to red. That lets you know the primary tank is empty and you are running on the 2nd tank. You then flip the lever to the 2nd tank, remove the primary tank to get refilled. A BIG misconception is to put the lever midway which defeats the purpose of the Auto change over design. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
