GASMAN6674
Dec 13, 2016Explorer
The "indicator" section of the regulator is the 1st stage of a two stage system. It takes tank pressure and reduces it to 10 psi for the second regulator. If the inlet pressure drops below 10 psi it will/should switch to reserve tank and switch indicator which tells you the tank the knob is pointing at is "empty". Switch the knob and you can remove the empty tank without loss of product or service.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
