WNYBob
Dec 13, 2016Explorer
I replaced my non-indicating manual dual tank setup with an automatic one.
The instructions said the following:
1. Open one tank. Then bead the system (with the stove as mentioned previously)
2. Open the second tank. This system will fail over to the second when the first tank is empty.
Note: lever on indicator does not change whI have tank is being used! It changes the indicator ONLY,
That's what I have, sounds like there are multiple methodologies used by the mfg's.
JMO
JMO
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
