time2roll
Dec 13, 2016Nomad
path1 wrote:The actual timing does not matter so much as that it gets done. You can switch the lever as you remove the tank or when you install the full tank. Just so that the lever is pointed away from the most recently filled tank before you step away and call it good.
I'll make a special point to point the lever to other tank before removing the tank.
BTW the second tank may not take as long to empty as it has already been feeding the RV for some time.
If you have a choice I recommend Cavagna brand regulator and pigtails (amazon).
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
