Old-Biscuit
Jul 11, 2015Explorer III
pkunk wrote:
If it's on the very bottom of the tank it is not the relief valve. The relief valve is above liquid level and will blow vapor if the pressure gets too high. The pic above is looking at a service tank from above, not a MH tank from the side. Tanks have a drain plug on the bottom that is used only when the tank has no gas in it to drain the residual oil that accumulates over the years.
Actually it is a Safety Relief Valve.
When tank is made/used for RVs the relief valve is installed at bottom with a tube that goes to top of tank area (Vapor).
If relief valve was installed on top o\of tank like a skid mounted/residential tank then should relief valve open it would exhaust vapor inside an RV. Not a good idea.
Look at diagram posted.
That is an RV tank. And view is from side.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
