dougrainer
Aug 28, 2023Nomad
mcewena wrote:Dutch_12078 wrote:
A rack fabricated to hold two or three 20 lb BBQ cylinders upright could work using an automatic switchover regulator setup.
Can they be used/stored/transported on their side or 45 degrees?
NO. Just sandblast and repaint. In Texas, (most of USA) rust is not a concern, especially if surface rust. Usually just 4 bolts hold the tank in place. Most LP fillers (USA and Canada) have NO CLUE as to the regulations on ASME Motorhome LP tanks. Doug
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
