Gary45
Aug 31, 2023Explorer
What gets registered? Both Canada and the United States use the ASME Section VIII-1 code for pressure vessel construction but Canada has a CSA B51 standard that provides a more restrictive definition of what a PRESSURE VESSEL is. Canada also registers FITTINGS – items that in other countries would be considered too small to need registering. Likewise we also register many PIPING SYSTEMS in Canada. All vessels, fittings and piping systems need to be built under appropriate quality control programs.
Reading the Canadian CSA B51 there is a clause stating that type 3 and 4 pressure vessels are required to be recertified every 20 years. Steel motorhome ASME pressure vessels are type 1 tanks which only require a visible inspection so keep clean and painted.
