golf_bears's avatar
golf_bears
Propane tank Valve Problem???
We’re currently at Llano Grande RV Park in Mercedes, TX.
Needed to have one of our 40# propane tanks filled yesterday. Propane is delivered to the park from a local propane dealer directly to your site.
So they go to fill the tank but the valve is stuck and they can’t get it to pop free to fill the tank.
So here are my questions.
Can the valve be replaced or should I just get a new tank?
If the valve can be replaced, is this something I should consider doing myself, tank is empty of propane? Never worked on a tank. Can order valve at Amazon or a new tank from Amazon.
If I should have the valve replaced by someone do you have any recommendations on who/where locally?
If I should just get a new tank, any suggestions on where to get one locally.
Thanks for your help everyone.
  • we had the complete opposite happen once, it was cold out and we were having the motorhome tank filled and the valve froze in the open position and could not get it disconnected, an old timer that was working there came by and tapped the valve area with a brass wrench and ta-da the valve closed, I know this has nothing to do with your case, just sharing information to store away for a later time
  • Are you sure the tank is empty? I find it puzzling that the tank could be empty if the valve is stuck shut.
    Is it remotely possible you have a situation like below?
    AmeriGas: Troubleshooting Your Propane Cylinder
    www.amerigas.com/exchange/consumer/connect.htm?
    Connect Your Propane Cylinder. With today's propane cylinder safety valves, propane will no longer flow out of a cylinder simply by opening the hand wheel.
  • Get new tank locally,have them take old one away,so what if it costs a few bucks more,don't waste time and money on some thing that is defective.Time and money are for enjoying life.
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 07, 2025
