Squeezle's avatar
Squeezle
Propane tanks mystery???
I just upgraded from a small travel trailer with one small propane tank to a used larger travel trailer with two large propane tanks.Yesterday I wanted to check out my oven so I turned open the valve on one of the large tanks and immediately noticed a propane smell and heard a slight hissing. I made sure the connection valve was tight and tried again..same thing, so I turned the valve off and tried the other tank...same thing, smell of propane and hissing, also check tightness of connection. I tried pouring soapy water over the valves looking for a leak but saw nothing.I then disconnected one of the tanks and replaced it with a small tank of propane I was using for my barbque.When I turned the valve no hissing or smell of propane.I then took the larger propane bottle I had removed and attached it to my barbque..no hissing.no smell of propane..I reconnected the larger tank back on the trailer and tried again...hissing..smell of propane.I tried this procedure with the other large tank on the trailer and got the same exact results. I am at a quandary as to what the problem is...at this point I ready to just replace the two larger propane tanks with two smaller one like that are on my barbque...Does anyone have any idea what could be the problem? Thank you
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: Dec 27, 2024
