mobeewan
Dec 16, 2021Explorer
The propane cylinder valve has a built in spring loaded in-line check valve in the outlet of the valve where the POL fitting or acme nut with internal POL screws into the valve. That check valve feature was added in the 1980s to gas valves on propane cylinders. People would forget to shut off the cylinder valve before unscrewing a hose and gas would come shooting out of the cylinder. The check valve keeps propane from coming out of the cylinder when the hose is disconnected.
Keeping the valve hand wheel open and inserting a screwdriver into valve outlet and shoving the check valve poppet will cause freezing cold gas and maybe even liquid propane to blast your hand as you noted. It can also create a spark causing the gas to ignite and freezing cold gas or liquid will be the last thing to worry about after severely burning yourself by igniting your brand new homemade flame thrower.
It is possible something has come loose or gotten in the way that is keeping the in-line check valve poppet from depressing when the POL fitting / Acme nut is connected and not allowing gas to flow.
It is possible that the threaded retaining ring for the check valve has backed out and needs to be retightened. Some have a small hex in the center and some have slots 180 degrees apart.
An Allen wrench might be able to be used to tighten the retaining ring with the hex. I have one with the slots. And used a small piece of flat bar to retighten it. Can't remember if it was left or right hand threaded. Found out it was loose when liquid propane was squirting past the threads when i took it to get refilled. Tightened it up and all was fine to get it refilled.
Make sure the tank valve is completely shut off before playing with the retaining ring.
