orourkmw
May 19, 2022Explorer
Thank you. I was pulling my hair out. I followed every advice I could find on Google, except for the clown on YouTube who advised unscrewing the valve from the tank and dumping out the liquid propane.. He’s going to get somebody killed. Anyway, with the valve closed I spray WD-40 and used a torx screwdriver to push in the check valve, with the valve opening pointing away from me and gloves on, just in case. At first, very hard to push, but the more I worked it the easier it became. Thought I had it, but no flow, so I repeated the procedure, and had success. Two thumbs up for this advice… It sure is better than beating the tank on the ground
